It is currently Fri Aug 15, 2025 12:28 am
 Post subject: LMII Bearings and Cutter
PostPosted: Sat Feb 14, 2015 2:22 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Where is my math wrong? I use a .76" bearing expecting a .12" slot, I get .13". I test a .78" expecting .11", I get .12.
PostPosted: Sat Feb 14, 2015 3:59 pm
Did it not come with a chart? Here's ours. Bearing size above, cut size below...Image
PostPosted: Sat Feb 14, 2015 4:04 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I did not get a chart, but my calculations match yours. I'm saying when I measure depth of cut, I'm deeper by a hundredth than I should be. Fir my 0.8, I'm getting 0.11 for example
PostPosted: Sat Feb 14, 2015 5:11 pm
Are you mixing and matching stew mac stuff wth LMII? Are you sure your cutter is 1" across?
PostPosted: Sat Feb 14, 2015 7:40 pm
First name: Tom
Last Name: West
State: Nova Scotia
PostPosted: Sat Feb 14, 2015 7:58 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Lol. No, not mixing vendor bearings or cutters. I measured both the bearings and the cutter. Cutter is 0.999" on my calipers, 0.8" bearing measures 0.799". With that combo, I get a 0.11" cut. I use a precise bits collet. Router is pre-2011. I am using the long shank cutter. If I'm reading this correctly, I've got a 0.01" wobble. Maybe I should test with the short shank bit? I do seat the bit deep however.
This really is not an issue. I can just use the next size up. But I am confused why this is happening. Btw, I do not own Stew Mac bearings or cutters
PostPosted: Sat Feb 14, 2015 8:13 pm
First name: Trevor
Last Name: Gore
City: Sydney
Possibly lack of concentricity between the bearing mounting and the cutter itself? This would mean that one blade on the cutter does most of the work and you may be able to see witness marks on the blades to that effect.
I use the LMII cutter and would say that it isn't the smoothest cutter I've got, but workable. I have just one router that is actually zero run-out, and even in that router it is fairly rough running, so either eccentric, out of balance or both.
http://www.goreguitars.com.au
PostPosted: Sat Feb 14, 2015 10:00 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Probably, I don't think I've ever actually measured cuts before. Just do quick estimates, then pick bearings that get desired results. I suppose I'm not surprised at this.
PostPosted: Sun Feb 15, 2015 9:49 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
I use the SM cutters and bearings, very smooth cut. I get about 6-7 guitars out of a new cutter before the end grain cut gets too fuzzy. Here's a trick I learned from John Hall: Get some adhesive backed copper tape from Hobby Lobby, its in the stained glass supplies. Very thin, about .002, and you can wrap it around bearings to dial in an exact fit for your bindings or purflings.
It will probably be alright.
